krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
dsm1212
Mar 17, 2013Apprentice
With DynDNS the IP in use is the one assigned to your router by your ISP. Your Router is then set to port forward to your NAS. So if you do a ping jumbo frame test you want to do it to the "external" IP of your router or to the dyndns name you have assigned. Most likely your router is not set to respond to pings though so the test won't work.
I am interested in your final answer though. I have one PC in my house that will not access the NAS using the dyndns name. The others work fine. I don't understand what is special about that system. It doesn't matter because it's not a laptop so it always uses the internal name, but I do wonder why it won't work. What error do you get? In my case the system does get an authentication challenge so it's reaching the NAS but after entering the password the browser stays blank. I've futzed with browser caches and what not but I just can't figure it out. I don't see where you've said exactly what error you get. Could you describe it?
steve
steve
- Mar 14, 2019Retired_Member
