krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
Mar 21, 2013Guru - Experienced User
Well, if your client sends a jumbo frame, it certainly will fail to pass through your router (either from inside or outside). You've already proven that with your ping test.
krylon wrote: Pinging the internal IP of the router and the external IP of the router both fail with -f -l 8972. I'm not really surprised by this at all. If I ping my external address from within the LAN it will respond to the ICMP, even though I've asked it not to. The ping fails when outside of the LAN, as expected.
I'm not convinced that the router is the problem and I'll try and explain this again :) If I run a webserver on a spare PC with Jumbo Frames enabled, on the same switch, same router (and configure the port forward to the spare computer instead of the NAS), then I can use the external address on the LAN with jumbo frame enabled clients. The same configuration fails on jumbo frame enabled clients when I host the webserver with the NAS with jumbo frames enabled. However(!), when I am outside of the LAN, at the office for example, then the external address will work with jumbo frames enabled on the NAS, but when I get home then it fails on the LAN.
Part of the analysis here is to figure out if the browsing to your PC web server actually uses packets > 1500 bytes. You seem to be assuming that it is doing that, simply because JF are enabled However, it is not that simple. If your PCs always sent >1500 byte packets simply because the interface allows them to, then you wouldn't be able to browse the internet at all - since the internet certainly does not carry JF.
The NAS attempts to sort out if JF are actually available on the connection. I suspect that negotiation isn't working correctly in your scenario - that is it is trying to send a JF, and it isn't getting through. Also, I am thinking that the PC web server simply isn't using them. One way to test this is by installing wireshark on the PC. The trace is complex to understand, but it should be pretty easy to tell if you are receiving/sending packets > 1500 bytes when you connect to frontview via the local LAN connection.
Are you seeing enough performance gain from JF to make pursuing this worth the bother? Also, the failure case is pretty narrow - you can connect via internal IP at home, and external IP on the road. It only fails when you try to connect with external IP at home, which is a nuisance but can be avoided easily enough.
- Mar 14, 2019Retired_Member
