krylon
Mar 10, 2013Aspirant
Enable Jumbo Frames Causes External Hostname Problem
I use my ReadyNAS to host my web page. If I enable jumbo frames on my NAS and my PC then I can no longer access my web page using my external hostname (dyndns.org address) while on the LAN. I have to ...
krylon
Mar 24, 2013Aspirant
StephenB wrote: I think we are talking past each other. I am not disputing your tests results - just trying to point out that just because JF are enabled on the PC doesn't mean that the web server is sending (or receiving) jumbo packets for the web pages you are browsing.
Thanks StephenB I see what you mean and I agree. This problem is a real quirk but at least I'm not the only one! Hopefully Netgear can help dsm1212 and I on this one since we have the same symptoms.
- Mar 14, 2019Retired_Member
