tinymonkey1
Nov 27, 2018Aspirant
Enable rsync/ssh/frontview from tech support mode on ReadyNAS NV+?
My ReadyNAS NV+ went into storage, and came out copletely locked down. It doesn't respond to http, https, ssh, rsync, and doesn't show up as any kind of network share. I've tried booting via USB, a...
Nov 27, 2018Guru - Experienced User
If sounds like you need to extract data from the NAS - is that correct?
Also, what firmware is your NAS running? Do you recall if you were running XRAID or FlexRAID?
tinymonkey1
That's right, I'd like to get my data off of the NAS however I can manage. I'd settle for something hacky. It's running RAIDiator-4.1.16, and yes, XRAID I believe.
- StephenBNov 28, 2018Guru - Experienced User
Assuming XRAID - once you are in tech support mode, you mount the OS partiton and chroot in
# start_raid.sh
# mount /dev/hdc1 /sysroot
# mount --bind /proc /sysroot/proc
# mount --bind /dev /sysroot/dev
# mount --bind /dev/pts /sysroot/dev/pts# chroot /sysroot /bin/bash
If you were using flexraid, then the first mount would be /dev/md0 instead of /dev/hdc1. Everything else is the same.
You can then attempt to mount the data volume (best to do this read-only)
# vgscan
# vgchange -a y# mount -o ro /dev/c/c /c
If that all works, you can mount a USB drive, or try to use rsync to offload your data.
Of course if the RAID isn't in a good state, the commands will fail at some point. If that happens, I suggest going to RAID recovery, and not attempting to fix it by hand. If you can connect your disks to a PC (either SATA or USB dock), then R-Studio might be worth a look. https://www.r-studio.com/ Netgear also offers a data recovery service: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
- tinymonkey1Nov 28, 2018Aspirant
Thank you so much! I had figured out the first few steps, but the rest would have taken me quite a lot of time. You just saved me a lot of pain and suffering!
