jkimmds
Dec 11, 2012Aspirant
Enter Network Password Problem
When I create a new share on NV+ and then try and access it from my Windows 7 PC, I am asked for Enter Network Password in a windows security popup(enter your password to connect to 192.169.1.70). Wh...
Dec 11, 2012Guru - Experienced User
With share security the password is whatever you set for the share.
Generally share security is not recommended (as it doesn't always play nicely with many operating systems). You could try switching to user security.
