jkimmds
Dec 11, 2012Aspirant
Enter Network Password Problem
When I create a new share on NV+ and then try and access it from my Windows 7 PC, I am asked for Enter Network Password in a windows security popup(enter your password to connect to 192.169.1.70). Wh...
loekieloekie
Mar 16, 2014Tutor
Its a bug.
Set an password in the share list, save.
Remove the password in the sharelist and save again, now you can connect again as guest.
- OsceolaOct 22, 2015Aspirant
Worked for me too! Thanks!
