Jens1
Jul 31, 2011Aspirant
Eratic behaviour, when using backslash instead of slash
This is a readyNAS Du with newest software release: 4.1.7 I defined a backup job for the c-drive to external USB on the front and defining "Backup\Monday" as the destination path. The effect: If...
ReadySECURE
Aug 06, 2011Apprentice
Hello,
Good practice is to check to make sure the backup is completed in it's entirety on the first full backup. You should be able to use the test connection to verify if a path is valid or not.
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
