glashoppah
Apr 13, 2013Aspirant
"ERR: Could not find internal fla"
ReadyNAS was working seemingly normally, however a backup job was failing stating that an external USB drive was "readonly". This drive is one of a pair I use to back up important files, the other of...
mdgm-ntgr
Apr 13, 2013NETGEAR Employee Retired
Remove RAIDiator-x86-4.2.15 from your USB key and put the 4.2.22 image on it. Then try a USB Boot Recovery again. If you do this it should format the internal flash and put 4.2.22 on it.
