Wil31
Apr 02, 2018Tutor
Erreur can_overcommit
Hi everybody, My ReadyNAS 104 version 6.9.2 didn't respond. I rebooted it. One hour after Boot process, only one message displays : can_overcommit+20 I don't have SSH or Web access, only ...
- Apr 02, 2018
One option is to use paid support (my.netgear.com).
Can you boot the NAS in read-only mode using the boot menu? See pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Wil31
Apr 02, 2018Tutor
Apr 02, 2018Guru - Experienced User
- Wil31Apr 02, 2018Tutor
Thanks for your fast answer.
I will test your solution.
I booted in "Read only" mode.
The NAS displays "Resync 33,34 %".
I can access Web interface.
- StephenBApr 02, 2018Guru - Experienced User
Good. You should confirm that you have access to your data.
Wait for the resync to complete. While that's going on:
- Most importantly, you should be backing up the data on your NAS before you reboot. If you need USB drives to do that, then purchase them right away. Back up the most critical data before then (as much as you can).
- click on the volume setting wheel and see if quotas are enabled. If they are, disable them.
- It would also be good to disable services that you don't need or can live without. For instance, the antivirus service.
