Wil31
Apr 02, 2018Tutor
Erreur can_overcommit
Hi everybody, My ReadyNAS 104 version 6.9.2 didn't respond. I rebooted it. One hour after Boot process, only one message displays : can_overcommit+20 I don't have SSH or Web access, only ...
- Apr 02, 2018
One option is to use paid support (my.netgear.com).
Can you boot the NAS in read-only mode using the boot menu? See pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Apr 02, 2018Guru - Experienced User
Wil31 wrote:
The remaining time is 70 hours !
May I update firmware to 6.9.3 to avoid any problem ?
Not now. Wait for the resync.
Wil31
Apr 02, 2018Tutor
OK. I don't use antivirus.
I will follow your advices and come back here when resync and backup are done.
Many thanks.
- Wil31Apr 12, 2018Tutor
Hi StephenB,
Good News !
After RAID reconstructing, I could access all my datas then I made backups.
After rebooting in normal mode, all is ok.
I updated firmware 6.9.2 to 6.9.3 with success.
Thank you for your help.
- StephenBApr 12, 2018Guru - Experienced User
Great! Thx for posting the outcome.
