oldfart825
Jul 02, 2020Guide
Error: 0x80004002 accessing NSA
Okay, here's my problem (yes, I know my NAS is old, but it works great for me): I just upgraded my daughter's system - fresh install of Windows 10 Home 64bit, version 1909. At this time SMB 1 is enab...
- Jul 03, 2020
Okay... I unenabled both NetBIOS over TCP/IP and SMB1, restarted pc, re-enabled both again, and added the address and device name into the Hosts file. Restarted pc. No change. Looks like the only way is through the net use command, and that will have to work for now. Just an incentive to replace the NAS as soon as I can.
Thanks everyone for the help! If anyone has any other suggestions I'm certainly open to them.
Marc_V
Jul 02, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you tried toggling Netbios, SMB and restart the PC again? It's isolated on your daughter's PC.
oldfart825
Jul 02, 2020Guide
I'll try toggling the NetBios and SMB settings and see if that has an effect. Thank you!
