oldfart825
Jul 02, 2020Guide
Error: 0x80004002 accessing NSA
Okay, here's my problem (yes, I know my NAS is old, but it works great for me): I just upgraded my daughter's system - fresh install of Windows 10 Home 64bit, version 1909. At this time SMB 1 is enab...
- Jul 03, 2020
Okay... I unenabled both NetBIOS over TCP/IP and SMB1, restarted pc, re-enabled both again, and added the address and device name into the Hosts file. Restarted pc. No change. Looks like the only way is through the net use command, and that will have to work for now. Just an incentive to replace the NAS as soon as I can.
Thanks everyone for the help! If anyone has any other suggestions I'm certainly open to them.
Jul 03, 2020Guru - Experienced User
Does entering \\nas-host-name in the file explorer address bar work? (using the real hostname of course)? Did you try pinging the hostname from cmd?
If the issue is that the network neighborhood is incorrect, then you should still be able to create a desktop shortcut that opens file explorer and shows the NAS shares. You should also be able to add a network location to the main file explorer pane.
So you do have other options that don't require net use.
oldfart825
Jul 04, 2020Guide
Yes, entering the device address in Explorer works, and I can ping the device. After much hair pulling I can now map the NAS drive the way I should, but it still doesn't appear in Explorer on my daughter's machine the same way it appears in mine. When I set mine up, all I had to do was enable NEtBIOS over TCP/IP and SMB1 and I was good to go. Hers refused to so so. After toggling both on and off and restarting several times, adding the NAS into the Hosts file, restarting it is accessable without going through the net use command. I would love to know why this machine was so difficult.
- oldfart825Jul 04, 2020Guide
The network neighborhood I don't know about. I don't use a workgroup or anything, and the NAS still doesn't show up in Explorer under Computers in the right pane, or under Network as it does on mine. It only shows up in Storage in the right pane.
Oh, and using \\nas-host-name does work.
- SandsharkJul 04, 2020Sensei
Right-click on "This Computer" and select "Properties". On that pop-up, it will list the workgroup. If that is different on the two computers, then that's the likely issue with it not appearing in Network. "Change Settings" on that same pop-up will allow you to change it.
But the problem of not being able to easilly access it without resorting to using the HOSTS files is something that has evaded many, myself included. You see postings all over about Linux SMB and Windows having this issue in come cases (Not just ReadyNAS and often not all computers on the same network), and Microsoft just gives their usual "try this" crap that works for nobody and ultimately takes no responsibility.
- StephenBJul 04, 2020Guru - Experienced User
... the NAS still doesn't show up in Explorer under Computers in the right pane, or under Network as it does on mine. It only shows up in Storage in the right pane.
Not showing up under "computers" is what I mean by the network neighborhood (which is an old windows name for this).
This particular aspect has been reported before, and there is no sure-fix for it that I've found here or in other forums. You can waste a lot of time trying to get it to work.
My advice is to use the four workarounds (perhaps in combination).
- learn to enter \\nas-name into the address bar of file explorer
- create a desktop shortcut that opens up \\nas-name or \\nas-name\sharename in file explorer when you click on it
- add a network location to the main file explorer window that opens up a NAS share.
- map the shares you want to access with net use with /persistent:yes
These are all pretty easy to do. I just enter \\nas-name myself. My wife prefers using desktop shortcuts.
- oldfart825Jul 05, 2020Guide
I checked this, and all systems have the same workgroup - WORKGROUP. Since it's accessable now, we'll just go with that. I mean, I've never had problems with Windows, ever...(lol).
