goranfim
Mar 14, 2016Aspirant
error btrfs merge bio hook a0
Anyone found fix to btrfs merge bio hook a0 error? Firmware 6.4.2
- Mar 22, 2016
Hello goranfim,
Factory resetting the NAS will format the disks, deleting not only the settings but also the data stored to the disks.
Always have full backup as we always recommend.
kohdee
Mar 16, 2016NETGEAR Expert
The fix is likely fixing something with your file system. Maybe you've exceeded 85% allocation at some time or something improperly manipulated your disks like a hung device. Can you boot your system in read only mode?
- goranfimMar 22, 2016Aspirant
I had to factory reset the NAS, then it works. All files missing :(
- JennCMar 22, 2016NETGEAR Employee Retired
Hello goranfim,
