konnichiwa
Nov 24, 2015Aspirant
Error connecting - Backup job settings for MacBook Pro Yosemite to Readynas Duo v1
ReadyNAS Duo v1 Firmware RAIDiator 4.1.14 Standard File Protocols CIFS and AFP checked on Home network - Network IPv4 assignment using values from a DHCP server Macbook Pro OS X Yosemite 10...
konnichiwa
Dec 14, 2015Aspirant
I finally just ended up using FreeFileSync 7.6. It gives a lot more flexibility including Mirrroring, Updating and two-way syncing. Also has real-time syncing.
BrianL2
Dec 14, 2015NETGEAR Employee Retired
Hi konnichiwa,
Have you tried using just the folder name as the path (source)? Ensure that you have added your router gateway as one of the DNS in the global settings page. We will also test and investigate this problem that you've encountered. Lastly, are you using this 3rd party backup software in your MAC?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
