noopara
Dec 17, 2020Aspirant
Error connecting to remote server to check for update
Raidiator 4.1.16 & 4.17 After a week of trying everything that others have tried, I am unable to update the firmware on my ReadyNas units. I have two ReadyNas RND2000 V2 units. One of them has fi...
Sandshark
Dec 17, 2020Sensei
If your NAS is running V4.1.x software, then it is a V1, not a V2. Netgear had used a small "V2" on a sticker to designate a very small hardware change, then later re-used "V2" for an entirely different NAS. A true V2 says so on the front, not just on a sticker. Only true V2 units can run OS5.x.
You can download OS 4.1.16 (the last update for your NAS) at RAIDiator-Version-4-1-16-Sparc and do a local update.
SSH is not enabled by default. You can enable it with the add-on available at Add-ons-for-RAIDiator-4-1-3-Sparc .
- nooparaDec 17, 2020Aspirant
Sandshark,
THANK YOU for the information!
I am not surprised to learn that as they are pretty old units. The sticker on the bottom has a small v2 on it as you describe. Without ever actually seeing a real V2 version, how would anyone know that what I have is not a V2 version. I was able to get the units registered with Netgear, thanks to their support team, however in all of those many emails back and forth with them, they never mentioned that my units were v2 and not V2 and that the last version for v2 units was 4.1.16. They were very helpful in helping to get them re-registered but they get a bac grade for not maintaining compatiblity with the older units. It should still connect to the update server and say "no update available".
Thanks again for the quick reply.
-- greg
- SandsharkDec 18, 2020Sensei
The 32-bit SPARC processor 1GB memory limit of the Duo and NV+ V1 units is simply not a capable enough system that it would be even reasonably fast running a significantly more up to date OS. I doubt there is even a much newer Debian distro available for it that could be used for the core.
At some point, old technology just gets too long in the tooth to run modern OSes and apps. Would you expect a computer shipped with Windows XP to be capable of running Windows10 and Microsoft Word? I suppose there may be a few that will, but anybody doing so must be seeing horrendous performance.
And, frankly, I think OS4.1.x and 4.2.x are far better than 5.x that runs on the V2 systems. 5.x is, IMHO, very "dumbed down" to appeal exclusively to the home market. There were 4.x models sold for and actually used by commercial users. OS6 is definately a step in the right direction (though also now growing old), but is 64-bit only so that it has sufficient performance.
- resingJun 14, 2021Aspirant
This was so helpful. Thank you!
This v2 on the label caused me at least one day's worth of pain yesterday.
I tried so many different ways to get the firmware updated and it wouldn't have occurred to me to use the Sparc firmware instead of the ARM until I read this post.
