Ridcully
Apr 12, 2010Aspirant
Error connecting to. Win 7 starter issues ?
Is there a bug in the front view software? There are so many threads with people being unable to get the test connection to work and just being left wih error connecting to. Its obviously not just...
InTheShires
Dec 07, 2010Tutor
I'm guessing the OP eventually got this sorted as he never responded to the last post.
I'm having the same issues as above. "Error connecting" etc, etc.
This is the main error message I get from the log after it tries to run.
Reason for failure:
Unable to access remote path //PC1-PC/I:
I've tried with with ip address (static) and host name. Logins are correct and I can login via the laptop and view/edit intended backup path.
Ideas please?
I used to use secondary software for this, but decided I've give this a go via Frontview, as I assume this is one of it's intended purposes. I can go back to Second Copy if needs be, but now I'd like to get this working.
Thanks.
Reason for failure:
Ideas please?
Thanks.
