2ndNAS
Nov 16, 2015Apprentice
Error in delete snapshot 28004020002
Good evening. New RN202 delivered with Firmware 6.3.2, has 1*500Gb disk, loaded with less than 2Gb files into Backup share, set to Hourly snapshots. After the first night snapshots was change...
- Nov 17, 2015
It is somewhere in 6.3.5 for sure.
Try system->settings and look at the volume maintenance. In 6.3.5 you might need to schedule it, instead of running it on demand.
mdgm-ntgr
Nov 16, 2015NETGEAR Employee Retired
Your volume is quite full so a balance may not work. You want to get volume usage down to 80-85% before running a balance if you want to try that.
6.3.2 is old firmware btw. You may wish to update the firmware.
- StephenBNov 16, 2015Guru - Experienced User
I'd suggest 6.3.5 (you'd need to manually install that before you could go to 6.4.x anyway).
I'd pass on 6.4.0 for now, and wait for 6.4.1.
- 2ndNASNov 17, 2015Apprentice
Good morning, and thank you for your answers.
Upgraded firmware to 6.3.5 and decided to chalenge the "Auto snapshot delete" function that goes into action at 95% disk use. It actually deleted all the snapshots; but isn't 95% a bit late?
FWIW: I copied my local data drive, filesize total=257Gb, to the 460Gb disk space (55%); that generated warnings about > 90% disk usage (33Gb free of the 460Gb). So I figure I should use less than 50% of a disk.
Do you have further info regarding the amount of reserved disk space?
No problem deleting files to try the Balance function; but where is it?
- mdgm-ntgrNov 17, 2015NETGEAR Employee Retired
If volume usage exceeds 95% the oldest automatic snapshots will be automatically deleted until volume usage falls back below 95%.
I would recommend limiting your volume usage to ~80%.Under System > Volumes you would click on the settings wheel for your volume and choose the balance option.
