2ndNAS
Nov 16, 2015Apprentice
Error in delete snapshot 28004020002
Good evening. New RN202 delivered with Firmware 6.3.2, has 1*500Gb disk, loaded with less than 2Gb files into Backup share, set to Hourly snapshots. After the first night snapshots was change...
- Nov 17, 2015
It is somewhere in 6.3.5 for sure.
Try system->settings and look at the volume maintenance. In 6.3.5 you might need to schedule it, instead of running it on demand.
mdgm-ntgr
Nov 16, 2015NETGEAR Employee Retired
Your volume is quite full so a balance may not work. You want to get volume usage down to 80-85% before running a balance if you want to try that.
6.3.2 is old firmware btw. You may wish to update the firmware.
