2ndNAS
Nov 16, 2015Apprentice
Error in delete snapshot 28004020002
Good evening. New RN202 delivered with Firmware 6.3.2, has 1*500Gb disk, loaded with less than 2Gb files into Backup share, set to Hourly snapshots. After the first night snapshots was change...
- Nov 17, 2015
It is somewhere in 6.3.5 for sure.
Try system->settings and look at the volume maintenance. In 6.3.5 you might need to schedule it, instead of running it on demand.
Nov 16, 2015Guru - Experienced User
mdgm wrote:
6.3.2 is old firmware btw. You may wish to update the firmware.
I'd suggest 6.3.5 (you'd need to manually install that before you could go to 6.4.x anyway).
I'd pass on 6.4.0 for now, and wait for 6.4.1.
2ndNAS
Nov 17, 2015Apprentice
Good morning, and thank you for your answers.
Upgraded firmware to 6.3.5 and decided to chalenge the "Auto snapshot delete" function that goes into action at 95% disk use. It actually deleted all the snapshots; but isn't 95% a bit late?
FWIW: I copied my local data drive, filesize total=257Gb, to the 460Gb disk space (55%); that generated warnings about > 90% disk usage (33Gb free of the 460Gb). So I figure I should use less than 50% of a disk.
Do you have further info regarding the amount of reserved disk space?
No problem deleting files to try the Balance function; but where is it?
- mdgm-ntgrNov 17, 2015NETGEAR Employee Retired
If volume usage exceeds 95% the oldest automatic snapshots will be automatically deleted until volume usage falls back below 95%.
I would recommend limiting your volume usage to ~80%.Under System > Volumes you would click on the settings wheel for your volume and choose the balance option.
- 2ndNASNov 17, 2015Apprentice
I only find Defrag, Scrub, Export, Destroy (grayed) and Settings under System->Volume->Data
Just to make sure: The above is what I see when I click on the Settings wheel in the blue rectangel in the left side of the screen.
If I click on the new Settings wheel then a new window opens, top line says Data, and in the left side I can choose between 2 menus,
- Summary, where Checksum is enabled, and
- Disks, where information about my harddisks are displayed (funny, but disk 2 displays RPM: 0)
So I don't see the Balance option, is it introduced with firmware 6.4.0 ?
- StephenBNov 17, 2015Guru - Experienced User
