2ndNAS
Nov 16, 2015Apprentice
Error in delete snapshot 28004020002
Good evening. New RN202 delivered with Firmware 6.3.2, has 1*500Gb disk, loaded with less than 2Gb files into Backup share, set to Hourly snapshots. After the first night snapshots was change...
- Nov 17, 2015
It is somewhere in 6.3.5 for sure.
Try system->settings and look at the volume maintenance. In 6.3.5 you might need to schedule it, instead of running it on demand.
2ndNAS
Nov 17, 2015Apprentice
I only find Defrag, Scrub, Export, Destroy (grayed) and Settings under System->Volume->Data
Just to make sure: The above is what I see when I click on the Settings wheel in the blue rectangel in the left side of the screen.
If I click on the new Settings wheel then a new window opens, top line says Data, and in the left side I can choose between 2 menus,
- Summary, where Checksum is enabled, and
- Disks, where information about my harddisks are displayed (funny, but disk 2 displays RPM: 0)
So I don't see the Balance option, is it introduced with firmware 6.4.0 ?
Nov 17, 2015Guru - Experienced User
- 2ndNASNov 17, 2015Apprentice
Thank you StephenB,
System->Setting->Volume Schedule->Add is the way to go.
