Digital999
Mar 04, 2021Luminary
Error message or not?? How to eliminate it?
This error message started to appear on all of our ReadyNAS units when we add/modify/share folder contents. Stuff seems OK if the error m essage is ignored but it must mean something. Any hel...
- Mar 22, 2021
The solution to this issue is connected to the obtuse way the GUI provides guidance, or lack thereof.
Assume you have a NAS – called TEST_NAS.
You go to change the name System >> Settings(Gear) and enter TEST-NAS.
Change is accepted and life is good?? Not really.
You need to change System >> Settings >> HTTPS >> change the SSL Key Host value to TEST-NAS.local. Apply and reset the system.
And now stuff works as expected.
In my view, this is a ‘bug’ in the GUI. The initial change was accepted without any issues but it should have at least displayed and advisory message regarding the related ancillary change to the HTTPS SSL Key Host Value. Possibly this is not important for every name change but I would think so.
My view is that the initial name change should have triggered an option to change the SSL Key Host value along with an explanation of the parameters.
NETGEAR wanted to charge a $500+ fee for a support case that in my view was related to shortcoming in the GUI or documentation.
Digital999
I must not understand how to post screen shots.
1002030829 Invalid SSL Key Host Address (Trout_Video.local)(1 ) is the message
- JohnCM_SMar 04, 2021NETGEAR Employee Retired
Hi Digital999,
Can you download the NAS system logs then provide it to us so we can check? You may upload it to a cloud storage site then send me the download link via private message.
- Digital999Mar 04, 2021Luminary
I do not have access to cloud storage, at least as far as I know. Do you have an email and I can mail you the compressed log file.
- StephenBMar 05, 2021Guru - Experienced User
dropbox (among other services) will let you set up a free account you can use.
If you use gmail, you already have google drive. Similarly if you have an apple id, you already have icloud - and if you use a microsoft account with windows 10, then you have onedrive.
- Digital999Mar 05, 2021Luminary
File is uploaded
