scotterm
Jun 14, 2020Aspirant
Error "Netgear Storage is not accessible" when Factor Reset of Ultra 2
I have an old RNDU2000 (RND-2A is also written on the bottom). I had a Corrupt Root error. I have tried to do a Factory Reset. This gets to the setup promp in RAIDar ok. Details: ReadyNas shows IP...
- Jun 14, 2020
From your descripotion, I assume you are still running OS 4.2.x. That only supports SMB1, whihc is diosabled by default in Win10. I'm losing you a bit in your description of the sequence, but I think that you may need to enable SMB1. RAIDar uses another method to find the NAS, so it would still work.
If you do end up having to start over, you may want to consider updating to OS6.
Jun 14, 2020Guru - Experienced User
Can you try to ping the NAS after you get this message?
Have you tried browsing to https://192.168.0.68/admin ?
Sometimes a NAS will be unreachable briefly while it is formatting the disk(s). That shouldn't last very long with only one disk installed (unless that disk isn't healthy).
Sandshark
Jun 14, 2020Sensei
