vov1969
May 16, 2023Aspirant
Error ReadyNas 212 for create mount cifs
Hello, everyone! I'm trying to mount a folder on the NAS to the server Ubuntu. I write: "sudo mount.cifs //192.168.2.43/php_backup /mnt/php/ -o noperm user=myuser" or "sudo mount.cifs //192.168.2....
vov1969
myuser@ubntSRV:~$ sudo mount.cifs -o user=admin //192.168.2.20/BackUpPhP /mnt/php/
Couldn't chdir to //192.168.2.20/BackUpPhP: No such file or directory
May 17, 2023Guru - Experienced User
vov1969 wrote:Couldn't chdir to //192.168.2.20/BackUpPhP: No such file or directory
Did you run chdir after the mount command?
Assuming you did: you mounted to /mnt/php, so you'd need to chdir to there.
- vov1969May 17, 2023Aspirant
I don't run chdir. When I run -o before "//192.168... /mnt/...", it is "Couldn't chdir to //192.168.2.20/BackUpPhP: No such file or directory", and when I run -o after "192.168... /mnt/..." it's all right.
- StephenBMay 17, 2023Guru - Experienced User
Except you can't access the folder. FWIW, when I put the user name at the end, I also can't access the folder. No idea why.
But when I use the syntax I posted, I do have access to it.
Note, I am not running ubuntu. I tested out the command using another ReadyNAS - the share is on my RN102, the mount was done on an RN526x.
I have Ubuntu 14.04.
