vov1969
May 16, 2023Aspirant
Error ReadyNas 212 for create mount cifs
Hello, everyone! I'm trying to mount a folder on the NAS to the server Ubuntu. I write: "sudo mount.cifs //192.168.2.43/php_backup /mnt/php/ -o noperm user=myuser" or "sudo mount.cifs //192.168.2....
May 17, 2023Guru - Experienced User
vov1969 wrote:
and when I run -o after "192.168... /mnt/..." it's all right.
Except you can't access the folder. FWIW, when I put the user name at the end, I also can't access the folder. No idea why.
But when I use the syntax I posted, I do have access to it.
Note, I am not running ubuntu. I tested out the command using another ReadyNAS - the share is on my RN102, the mount was done on an RN526x.
vov1969
May 17, 2023Aspirant
I have Ubuntu 14.04.
