Jeje
Sep 26, 2016Aspirant
Error Volume data Raid Level 1, Not Redundant
Firmware 6.5.2 After adding a second 2 TB WD RED HDD both disks are being recognized and have a green check But there is an error saying Volume Dta: RAID level 1 , Not Redundant; 679.5GB (38%) of 1...
- Sep 26, 2016
Jeje wrote:
I had quite a number of spikes and surges because of tripping of the electric circuit. Maybe that has to do something with it?
A surge could have created some damage. Do you use a UPS?
The WD Red has a 3-year warranty, so you can RMA it. Western Digital will send you a recertified replacement, not a new disk. I'd probably do the RMA, but also buy a new replacement disk for the NAS. Then either use the RMA replacement somewhere else, or keep it on hand as an emergency spare.
Oct 05, 2016Guru - Experienced User
The btrfs file system will show some space allocated even if the volume is empty. So that part is normal.
Can you download the logs, and look at the disk_info.log? You can post it here (removing the two serial numbers if you like).
If both disks look healthy, I'd do a factory reset next (since there was file system corruption in the OS partition earlier on). But I think we should confirm disk health first.
Jeje
Oct 06, 2016Aspirant
This is what the disk_info.log says:
Device: sda
Controller: 0
Channel: 0
Model: WDC WD20EFRX-68EUZN0
Serial: WD-WMC4M1635698
Firmware: 80.00A80
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: Test
PoolType: RAID 1
PoolState: 1
PoolHostId: e348c4d
Health data
ATA Error Count: 5
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 31
Start/Stop Count: 129
Power-On Hours: 18072
Power Cycle Count: 98
Load Cycle Count: 1912253
Device: sdb
Controller: 0
Channel: 1
Serial: WD-WCC4M1ZVU14K
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: Test
PoolType: RAID 1
PoolState: 1
PoolHostId: e348c4d
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 30
Start/Stop Count: 29
Power-On Hours: 255
Power Cycle Count: 17
Load Cycle Count: 15
It also seems that one account was deleted Sep 29th. Have no clue how.
Thu Sep 29 2016 23:51:00 System: Automatic disk spin-down enabled.
Thu Sep 29 2016 23:13:05 Volume: Volume data is resynced.
Thu Sep 29 2016 23:12:24 Volume: Resyncing started for Volume data.
Thu Sep 29 2016 23:12:10 Disk: Disk Model:WDC WD20EFRX-68EUZN0 Serial:WD-WCC4M1ZVU14K was added to Channel 2 of the head unit.
Thu Sep 29 2016 22:56:08 System: Antivirus scanner definition file was updated to 201609291956.
Thu Sep 29 2016 22:40:25 Account: User 'jejeagency@gmail.com' was deleted.
Thu Sep 29 2016 22:39:53 System: ReadyNASOS background service started.
Thu Sep 29 2016 15:08:04 System: The system is shutting down.
Thu Sep 29 2016 3:07:33 Disk: Disk in channel 2 (Internal) changed state from RESYNC to ONLINE.
Thu Sep 29 2016 3:07:33 Volume: Volume data is resynced.
- StephenBOct 06, 2016Guru - Experienced User
The load cycle count on the first drive is way too high for a WDC Red - something is odd there.
I think I'd try the reset anyway, but maybe repost the stats again after the reset completes.
- JejeOct 10, 2016Aspirant
After doing a Factory Reset (with 2 other new disk, - trying not to lose any data from the previous marked corrupted disk meant for RMA), the newest firmware (6.6.0) was installed automatically and the stats are:
Successfully completed diagnostics System
- No errors found.
Logs
- No errors found.
The system is resyncing which will take another 3 hrs. After that I will try to replace the two disks with just the one which is meant for RMA to see if I could recover data.
Good news is that the REadyNAS is accesible again through the File Explorer.
- StephenBOct 10, 2016Guru - Experienced User
Just make sure the NAS is powered down when you switch the disks. I'd label the new ones by slot (not strictly necessary, but does no harm).
I hope you can recover data.
Unfortunately the RMA disk is no longer readable.
It is packed to be shipped.
Thanks for all the great help and information. It was a pleasure.
