jhoffer101
Aug 21, 2015Aspirant
Error when attempting to delete snapshots
Good morning, I am having issues when attempting to manually delete snapshots from our ReadyNAS. The error that is displaying when it does fail is 28004020002. After searching through your forums...
- Aug 25, 2015
Fixed.
Please do not reboot the system until the balance has completed. The balance will take some time to complete.
You can see the progress in the web admin interface.
Furthermore you can schedule a balance to be run say every 2-3 weeks.
Aug 21, 2015Guru - Experienced User
jhoffer101 wrote:
running the serial numbers it appears that it may be outta warranty. by 3 months.
Hardware warranty is three years, so I don't think that is possible. The 90-day software phone support could be up.
jhoffer101
ah ok. i will try this then. Thank you so much for your help.
- vandermerweAug 21, 2015Master
Ok.
Try the suggestions anyway, while you are waiting for support, they may not respond until next week.
- mdgm-ntgrAug 21, 2015NETGEAR Employee Retired
The 314 has a 5 year hardware warranty, 90 days phone support. If purchased on/after Jun 1, 2014 it has lifetime chat support as well.
Can you send in your logs (see the Sending Logs link in my sig) or if you have a case open let me know the case number?
