martin9911
Jun 07, 2015Aspirant
Error when trying to delete snapshot
Tried using another topic that´s related to this problem but since I didn´t get any answers I will try creating a separate topic.
My volumes are filling up with data and I regularly manually deletes snapshots to free data. But since some months ago I´m not able to do so. I get an error when i try.
28004020002
Error in delete snapshot
Code: 28004020002
Anyone have a clue what to do?
https://www.dropbox.com/s/u1nfj9l9mq4te ... 2.png?dl=0
28004020002
Code: 28004020002
- mdgm-ntgrNETGEAR Employee RetiredKyle, I have sent you a PM.
- menaboAspiranthi, i'm an italian user with RN 31200. I can't delete snapshot and now my free space is around 30 gb.
i've firmware 6.2.4. and i've tried to delete whit all the tricks found in this forum , but nothing happened.
The error code is 28004020002 Error in delete snapshot. Any help would be greatly appreciated!
thanks Graziano - mdgm-ntgrNETGEAR Employee Retiredmenabo I have sent you a PM
- mdgm-ntgrNETGEAR Employee Retiredmenabo your system is fixed. Some space is gradually being freed up.
- mdgm-ntgrNETGEAR Employee RetiredKyle_T as well as removing the snapshots I have expanded your volume capacity to what it should be.
- bburbank1AspirantHaving the same problem. Error code 28004020002 after upgrade to 6.2.4 on RN102.
Array is filling up and deleting files to no avail. Any help would be greatly appreciated!
Thanks. - mdgm-ntgrNETGEAR Employee RetiredSent you a PM bburbank.
- mdgm-ntgrNETGEAR Employee Retiredbburbank's system had the issue where the old snapshots were not upgraded. I have fixed the problem.
- markgsxAspirantGood Day all,
Wondering if someone could help me get some snapshots deleted. When I attempt to delete the snapshots I get an error message of "28004020002 Error in Delete Snapshot"
I have tried toggling the snapshot access on and off as well as defragging & scrubbing and nothing seems to work (as some other posts have recommended).
Any ideas or help would be greatly appreciated?
Thanks - MarcoTAspirant
Hi, I'm experiencing the same error here: when I try to delete snapshot I get the "error in delete snapshot 28004020002" message. I 've just installed firmware 6.2.4.
Also, trying to disable snapshots for a specific share, or trying to enable "allow snapshot access" I get "set protocol collection failed 1002030827" error clicking on OK or on APPLY.
I see that MDGM says that martin991's system has been fixed, but I can't see how....
thank you for any help
Marco
- rjoletAspirant
I am experiencing the same error as well when trying to delete snapshots after upgrading the firmware. (Snapshot failed. 28004020002) Could someone please help?
thanks
