aaseef021
Nov 14, 2017Aspirant
Error with Orbi and ReadhNas516
I get the follwoing error for my orbi and REadynas 516 (process:5974): GLib-GIO-ERROR **: Settings schema 'org.gnome.system.proxy' is not installed Can someone assist
Nov 14, 2017Guru - Experienced User
This error is on the NAS or on the Orbi?
Do you have the NAS set up to use a web proxy? What firnware is the NAS running?
Are you seeing any operational issues? Or just an error in the log?
aaseef021
I updated the firmware on the REadyNas 516 to 6.9.0 and that is when i started seeing the issue. I do not use proxy. Can you please assist why that error occurs. I did not see the error when the firmware was on a previous build.
- StephenBNov 14, 2017Guru - Experienced User
Are you seeing any problems? Or just an unexplained message in the logs?
