PeteCress
Jan 21, 2011Apprentice
Exact Steps For Getting Into Tech Support Mode?
Ultra-6, experiencing the infamous "Boot-Shutdown Loop". I'll call support as soon as I have the box in Tech Support mode and have the ID number. But the LED display goes dark instead of supplyi...
mdgm-ntgr
Dec 28, 2011NETGEAR Employee Retired
What do you see under the "Info" (far right) column in RAIDar?
By the plugin for TiVo, what exactly did you do to enable this feature? Simply try to enable it via Frontview under Services > Streaming Services > ReadyDLNA?
You haven't installed the EnableRootSSH add-on to enable SSH by any chance? If you have you could SSH in and attempt to fix the problem.
- Jan 17, 2024Retired_Member
