Mrcorvettegolfe's avatar
Feb 14, 2021
Couldn't get IP address
I have had this router for 2 years no problems until now. Wired devices have connection but wireless can't get an IP address. I have reset the router to factory specs and also have take off all the schedules in Security. Nothing seems to work. I have good internet from my cable modem. To test I have a Lynksys travel router and I can get wireless with that.
  • I downloaded the latest version again and installed. All seems to be working now. Thanks.
  • plemans's avatar
    What firmware version are you on?
    What modem/gateway is it connected to?
    Is the wireless broadcasting but just not able to connect? Is it connecting but saying "no internet"
    What exactly is happening?
    • Mrcorvettegolfe's avatar
      Mrcorvettegolfe
      Firmwave 1.3.1.64_10.1.36  I have automatic update and checked that this was the latest version
      I have Optimum cable modem which is an Aris model.
      I see that the wireless is broadcasting. It says "couldnt' obtain ip address" All wired devices work fine.
