PeteCress
Jan 21, 2011Apprentice
Exact Steps For Getting Into Tech Support Mode?
Ultra-6, experiencing the infamous "Boot-Shutdown Loop". I'll call support as soon as I have the box in Tech Support mode and have the ID number. But the LED display goes dark instead of supplyi...
mdgm-ntgr
Dec 29, 2011NETGEAR Employee Retired
I hoped that would solve it. The ReadyDLNA included in the latest firmware is actually newer than the version in the file you mentioned.
If Frontview has been broken somehow you will get the symptoms that you mentioned. The only way to fix it (if a OS Re-install doesn't work) is via SSH (which you don't have enabled) or tech support mode.
- Jan 17, 2024Retired_Member
