Kornettisten
Feb 28, 2019Aspirant
Exchanging from ReadyNAS RND4000 (Duo 2) to ReadyNAS 214
I remember the name of my ReadyNAS as Duo2 only, but registered as RND4000v2 in my profile. But in general I understand that it is not possible to move these disk from my old NAS to the new one I pl...
- Feb 28, 2019
First of all, an RND4000 is a four-bay model, not a Duo. You could have a v1 (Sparc) platform or a v2 (Arm) platform. The labeling is confusing, and many v1 owners mistakenly believe they own a v2.
If you tell us what firmware you are running, we can tell you what platform you have.
Kornettisten wrote:
But in general I understand that it is not possible to move these disk from my old NAS to the new one I plan to buy, the ReadyNAS 214?That is correct. You can reuse the disks in the new NAS, but they will be reformatted and all data would be lost.
So if you decommission your current ReadyNAS, then you will need to offload your data.
Another option you should consider is keeping your current ReadyNAS running, and use it as a backup to your RN214. If you do that, you'd get new disks for the RN214 (ideally leaving one or two slots empty for expansion later). Then you can use the backup job feature of the NAS to copy the files from the old NAS to the new one. That would be a NAS->NAS transfer, the PC wouldn't be involved.
After that's done, you can reverse those backup jobs, so that they'd automatically update the old ReadyNAS every day.
RAID alone isn't enough to keep your data safe, and if your current NAS is still operational, it's cost effective to repurpose it as a backup.
Feb 28, 2019Guru - Experienced User
- KornettistenFeb 28, 2019Aspirant
Model: ReadyNAS NV+ v2 Serial: <redacted> Firmware: RAIDiator 5.3.13 This is a 4 bay NAS, yes. I am not sure why I think of Duo2.
Thank you for advices!
2 disks in en each of the old and new NAS is probably appropiate for my small scale usage.
First of all I have to buy a new NAS.- StephenBFeb 28, 2019Guru - Experienced User
Kornettisten wrote:
Model: ReadyNAS NV+ v2 Serial: <redacted> Firmware: RAIDiator 5.3.13 This is the arm based platform (called a v2 here).
- KornettistenMar 07, 2019Aspirant
I am a very light user of the ReadyNAS compared to most people, I guess.
The files I transfered to an external disk and sent back again after the installation of the 214 model.
Later I will propably buy new disks and use the old NAS again. Waiting for good disc prices. ;-)
Now I have to learn about how to administrate external users and connection to a ReadyCloud share. But I have just began planning this part.
A surprisingly option is tha ability to reroute my GoogleDisk to the NAS. Nice, but frst of all I must get hold of all the users who are supposed to use my Cloud
Thank you for the support with the NAS exchange!.
