DeeCee521
Sep 28, 2013Aspirant
Exclude Recycle Bin from Back up
I have googled and googled, tried and tried. :oops: and canot find the solution. How do I exclude the CIFS Recycle Bin from rsync. I have tried ,"Recycle Bin",'Recycle Bin',Recycle\ Bin and all...
DeeCee521
vandermerwe wrote: I, and at least one other user, have also had problems with lists of folders to exclude:
http://www.readynas.com/forum/viewtopic ... 31&t=53260
It suggests that this was a known problem that should have been fixed.
Can you test to see if Recycle\ Bin works if it is the only folder to be excluded?
I'll give it a try. It will have to wait until I get to the offsite.
