plockerman
Mar 18, 2011Aspirant
exFat or ext3, that is the question....
I have windows 7, the NV+ uses ext3 but W7 does not, it uses NTFS or exFat for large volumes. My concern is simply that if my NAS goes belly-up, I want to be able to access the data on the backup driv...
markwoll
Mar 21, 2011Guide
A bit off of the question, but not a total hijack.
If you have converted your readynas disks to ext4, is an ext4 formatted usb drive supported?
Also would there be much performance difference?
mark.
mark.
