God666
Feb 13, 2012Aspirant
Expanding NV+
Hi Folks, I have a question related to progressive expansion of my NV+ as I can't seem to get it to expand to the full capacity and I suspect it is due to the sequence I have used to expand. Origina...
mdgm-ntgr
Feb 14, 2012NETGEAR Employee Retired
Your disks are not 4k sector partition aligned. Hence you may have poor write performance.
It's recommended to backup your data, ensure you are running RAIDiator 4.1.7 or later then do a factory default.
Have a look at Why you might want to factory reset a Sparc ReadyNAS
