God666
Feb 13, 2012Aspirant
Expanding NV+
Hi Folks, I have a question related to progressive expansion of my NV+ as I can't seem to get it to expand to the full capacity and I suspect it is due to the sequence I have used to expand. Origina...
donlew
Feb 25, 2012Aspirant
I seem to be having a similar problem with resizing. The unit is sending a not very helpful error message of "Disk capacity expansion error. resize2fs". My partion log contains:
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 3907008687 1951200343 5 Extended
/dev/hdc5 4608003 976736305 486064151+ 8e Linux LVM
/dev/hdc6 976736312 3906992303 1465127996 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 3907008687 1951200343 5 Extended
/dev/hdg5 4608003 976736305 486064151+ 8e Linux LVM
/dev/hdg6 976736312 3906992303 1465127996 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
/dev/hdi1 2 4096001 2048000 83 Linux
/dev/hdi2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdi3 4608002 3907008687 1951200343 5 Extended
/dev/hdi5 4608003 976736305 486064151+ 8e Linux LVM
/dev/hdi6 976736312 3906992303 1465127996 8e Linux LVM
I've upgraded from four 500MB drives to four WD2002FAEX-007BA0 (1862GB) drives under X-RAID and firmware 4.1.8. The existing volume is still redundant and accessable and other than the inability to expand to the full capacity of the new drives, everything is working OK. Back-up and factory reset? :(
