God666
Feb 13, 2012Aspirant
Expanding NV+
Hi Folks, I have a question related to progressive expansion of my NV+ as I can't seem to get it to expand to the full capacity and I suspect it is due to the sequence I have used to expand. Origina...
mdgm-ntgr
Feb 25, 2012NETGEAR Employee Retired
PapaBear wrote: If this is an older NV+ that was shipped before RAIDiator 4.1.x came out, and was later upgraded to the newer version, but never was factory defaulted on 4.1.x, then your system may be still using 4k blocks rather than 16k blocks which are necessary for expansion beyond 2GB.
Almost right. The 4k block size doesn't work with expansion beyond 5TB (i.e expansion when you have 4x2TB disks in place).
So backup and factory default is the way to go here.
If your disks are not 4k sector then it is possible to manually expand to 5TB but that's not recommended.
