God666
Feb 13, 2012Aspirant
Expanding NV+
Hi Folks, I have a question related to progressive expansion of my NV+ as I can't seem to get it to expand to the full capacity and I suspect it is due to the sequence I have used to expand. Origina...
scud80
Mar 02, 2012Aspirant
partition.log:
Disk /dev/hdi doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 32 4096031 2048000 83 Linux
/dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hde3 4608032 3906992335 1951192152 5 Extended
/dev/hde5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 32 4096031 2048000 83 Linux
/dev/hdg2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdg3 4608032 3906992335 1951192152 5 Extended
/dev/hdg5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
