God666
Feb 13, 2012Aspirant
Expanding NV+
Hi Folks,
I have a question related to progressive expansion of my NV+ as I can't seem to get it to expand to the full capacity and I suspect it is due to the sequence I have used to expand.
Originally it had 2 x 500GB drives.
I added a third disk of 2TB capacity which then pushed it up to 923GB capacity. It was then that I realised that it would limit the size of the third disk to the smallest of the two original disks so the 2TB was being wasted.
All good, bought two more 2TB drives, replaced the first and let it init etc, all worked fine and remained, as expected at 923GB capacity.
Replaced disk 2 and let it init etc at which point I rebooted to complete and expected to see 4TB capacity (3 disks of 2TB each). It remains however, at 923GB capacity!
Is this because the progressive disk additions have all been working from the original base of 500GB and the NV+ is not bright enough to realise it now has overall a much larger capacity?
Or is it that I am not bright enough and have missed something obvious?
My bold assumption is that I may be able to do a factory reset and let it trash what is there and start from scratch however, I am also fundamentally lazy and don't really want to set up all my shares etc again.
Any thoughts on what I have done wrong/right and a possible way ahead to get the full capacity?
Cheers,
Gary
Cheers,
Gary
- mdgm-ntgrNETGEAR Employee Retired
scud80 wrote: if i restore my previous configuration (with volumes etc) this shouldn't be affected correct?
Correct
