reburns
Sep 19, 2016Aspirant
Expansion failed - Pro Pioneer 6
Hello -
Adding a 6th HDD to this Pro Pioneer failed. I believe that this was built using 4 each 4TB HDDs and later adding a 5th and now attempting to add a 6th. Is the issue a 8TB expansion limit? I will happily upload logs, but don't see how to attach the file, or add a download link. The drives are WD40EFRX. The other thing to observe is that the volume was very full before attempting the expansion. If that's an issue, I can free up some space first.
Thank you!
| Hostname: | Ascent-Pioneer |
| Model: | ReadyNAS Pro 6 [X-RAID2] |
| Serial: | 20S40CRL00187 |
| Firmware: | RAIDiator 4.2.28 |
| Memory: | 3072 MB [4-5-5-15 DDR2] |
| IPv4 address: 1: | Not Connected |
| IPv4 address: 2: | 192.168.1.4 |
| Volume C: | Online, X-RAID2, 6 disks, 98% of 14 TB used |
If a Netgear moderator requests logs, you email them using this procedure: http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-readynas-community-moderators
There is an 8 TiB growth limit, but you didn't exceed that.
The problem is the other constraint on growth - a volume cannot grow over a 16 TiB size. After 5 disks you were at 16 TB (~ 14.5 TiB), the 6th would take you to 20 TB (~ 18.1 TiB).
What you can do is back up all the data and do a factory reset with all drives in place. Though the volume can't expand to more than 16 TiB, the NAS will create a 20 TiB volume if you do this.
Since you are facing a factory reset anyway, you could take the opportunity to switch to OS 6 - which has no known expansion limits, and which has other features that aren't available with OS 4.2. One thing to factor in - you will lose Netgear support.
- reburnsAspirant
Ok, I'll consider a factory reset and OS 6. AFAIK, the 4TB HDDs I am using is outside Netgear support already. (?)
Can you point me to directions for upgrading to OS 6?
The legacy HCL aren't updated very often. Though the pro pioneer list does include three 4 TB models, including both WD Red drives and the Seagate VN drives (now branded as "Ironman").
See the highlighted post in this thread ( https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/m-p/897023/highlight/true#M50465)The cliff-notes version is
1. Install the add-on PREP4TOR6_0.1-x86.bin. Don't reboot.
2. Install the firmware R4toR6_latest.bin
3. RebootThe reboot will automatically trigger a factory reset, which of course destroys the data on the NAS and the configuration.
