droz1
Feb 19, 2015Aspirant
Experience with OS 6 on Legacy....
Does anyone have any thoughts, tips, caveats to running OS6 on legacy hardware? I see lots of complaints, problems, etc. I'd like to hear from anyone that's got it running and using it on a day ...
dsm1212
Feb 24, 2015Apprentice
I'm very happy with OS6 6.2.2 on a PRO6 (with upgraded processor and 8GB memory). I'm running ssh, plex, subsonic, sickbeard/couchpotato/headphones, utorrent, openvpn, logitech media server, and of course file sharing (photos, backups, videos). The newer linux distro in OS6 made using open source much easier so many of these I installed and configured myself.
steve
steve
howarddavidp
Nov 04, 2015Tutor
Hello,
New here, if I have a ReadyNAS Pro 6 RNDP6000-200, which OS6 file should I use, since it will not show up on my support page? Which other NAS should we look at to download the OS6 file?
Thanks,
David
- mdgm-ntgrNov 04, 2015NETGEAR Employee Retired
See e.g. the third post in this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/td-p/897021
You need a special image to do the upgrade and don't forget to backup your data first.
After upgrading to OS6 subsequent firmware updates are done using the ordinary OS6 x86_64 image file which is used for the 300 series and up in desktop models.- howarddavidpNov 10, 2015Tutor
Hello,
My upgrade went without issue, very easy and worked 1st try. I used the 2 files from my other post, and I backed up everything so it worked out well. However, when I restored, only 1 of my backups came back. Luckily, the other 2 backups were not important, so it did not matter.
Very happy, all is well. Thanks for your reply.
David
- Supertramp11Dec 13, 2015Luminary
When I upgraded my PRO 6 to OS6 a few months ago, it immediately went to version 6.3.5.
I like to keep a copy of this version as a backup on my PC. Is there a place where I can dowload the OS 6.3.5 firmware for the PRO 6?
It doesn't appear here: http://downloadcenter.netgear.com/en/product/RNDP6000-200NAS%20(ReadyNAS%20Pro%206)
Thanks.
- DaneADec 14, 2015NETGEAR Employee Retired
Hi Supertramp11,
You can download firmware v6.3.5 on this link for purposes of having a copy of it.
For me, you cannot use firmware v6.3.5 on your Pro 6 even if your Pro 6 has been updated to OS 6.x firmware. Its because firmware v6.3.5 was released exclusively for the ReadyNAS RN200 series only. Furthermore, the RN200 series are Arm-based NAS unlike the Pro 6 which is an Intel-based NAS.
DaneA
NETGEAR Community Team
