droz1
Feb 19, 2015Aspirant
Experience with OS 6 on Legacy....
Does anyone have any thoughts, tips, caveats to running OS6 on legacy hardware? I see lots of complaints, problems, etc. I'd like to hear from anyone that's got it running and using it on a day ...
howarddavidp
Nov 04, 2015Tutor
Hello,
New here, if I have a ReadyNAS Pro 6 RNDP6000-200, which OS6 file should I use, since it will not show up on my support page? Which other NAS should we look at to download the OS6 file?
Thanks,
David
mdgm-ntgr
Nov 04, 2015NETGEAR Employee Retired
See e.g. the third post in this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/td-p/897021
You need a special image to do the upgrade and don't forget to backup your data first.
After upgrading to OS6 subsequent firmware updates are done using the ordinary OS6 x86_64 image file which is used for the 300 series and up in desktop models.
