willy134uk
Aug 01, 2012Aspirant
extracting rars with duo v2
hi is there a easy way of extracting rar files with the duo v2 ive read you can do via ssh but to complicated ive connected via ssh using telnet but dont know what to do from there thanks mark
mdgm-ntgr
Dec 04, 2012NETGEAR Employee Retired
You would need to add lines for "non-free" in addition to your "main" ones.
unrar is in the "non-free" section. See http://packages.debian.org/squeeze/unrar
Not sure whether or not unrar would install on the Duo v2 but you could give it a try.
