Spacedementia87
Oct 29, 2016Aspirant
Extremely slow transfer speeds over ethernet
I have had my ReadyNAS for a few years now and have always experienced slow network speeds. I have always just assumed that the ReadyNAS was just slow, however I have been researching recently an...
Spacedementia87
Oct 30, 2016Aspirant
Ok well I did some tests.
I use hdparm to do read speeds on both units and got around 100MB/s
So then I used dd to do a write speed test, around 55MB/s on the PC and 30MB/s on the NAS.
So all seems ok there.
So I did rsync on the PC to a different partition, got around 40-50MB/s
Did rsync on the NAS from one partition to the other, only 4MB/s.
Hmm there is the issue...
I have checked the SMART stays on the drive. That seems fine. Any ideas?
- JBDragon1Oct 30, 2016Virtuoso
So you are using more then 1 partition. Is it 2 partitions with 2 drives each? In a RAID1 setup for each? 1 Data drive the other a clone with each partition? OR because you're going this 2 partition way, you're going with RAID0, and taking advantage of both HDD for each of the 2 partitions because you are backing up onto the other 2 HDD's, which in effect is a backup.
Going this route can makes sense, ,but you lose 1 HDD for storage space and using RAID5. On the other hand, you have a full backup always instead of having to do some type of backup externally. So my guess is you're going the RAID0 route?
Still doesn't explain the rsync issue. I looks like you do get some performance hit uisng rsync over just copying for example because of the overhead, but it shouldn't be 4MB/s slow. I don't have a way to test myself and see what happens. Looking at this post:
https://community.netgear.com/t5/Using-your-ReadyNAS/slow-rsync-transfer-speeds-NV-gt-NV/td-p/844551
Copying he's getting around 25 MB/s, and using rsync it's dropping down to 1.4MB/s. That's even worse then you! I couldn't imagine taking that big of a performance HIT just using rsync. Is this a issue with a ARM processor? I would think far more people would be complaining if this was a big issue.
You need to check your Logs and see if you're having backup errors. What way is your HDD's formated? You wan to go into the NAS to System/Logs and click on Download Logs. You'll get a lot of Data this way. May want to look at the backup file logs. Maybe the disc_info log. Maybe network_settings and look and see if you're getting any RX or TX packet errors. smart_history looks like a good one. allso volume looks like a good log. You should see things like Latest Self Test: Passed on all the HDD's.
All I can do at this point is offer the few tips above.
