Spacedementia87
Oct 29, 2016Aspirant
Extremely slow transfer speeds over ethernet
I have had my ReadyNAS for a few years now and have always experienced slow network speeds. I have always just assumed that the ReadyNAS was just slow, however I have been researching recently an...
Spacedementia87
Oct 30, 2016Aspirant
Sorry I thought I already had that in my title!
Yes it is a Duo V1 running 4.1.13
I am doing this because the system will not accept firmware upgrades or shutdown without a command through terminal so obviously something is messed up!
I get that rsync is CPU bound, but I am running the command from the desktop PC with the NAS share mounted via NFS so this shouldn't use the NAS CPU at all?
I am currently getting about 4MB/s, this seems pretty slow considering it should not be involving the NAS CPU.
When you say transfer over NFS, do you mean using a cp command? The problem with that is not ability to resume a failed transfer.
I do not have jumbo frames enabled and the max MTU my router seems to support is 1500. I also don't know how to test if my Linux PC can support jumbo frames.
I have journalling enabled because I don't have a UPS and we have been having a few power cuts recently.
Oct 31, 2016Guru - Experienced User
That's correct, and you should be getting NFS speeds. I agree they should be faster.
That is what I meant, but I missed the fact that you are aleady mounting as NFS.
I didn't mean to suggest that you enable them. Often turning them on will cause the speeds to drop (esp if your router or PC doesn't support support them).
This might be the key.
Have you checked for a full OS partition (e.g., df . -h and df . -i from terminal)?
