Grizzi
May 04, 2019Aspirant
Failed update from 4.2.31 to 6.10.0, Boot Menu unavailable, 4.2 USB recovery not working in Win10
Hi,
Just did, what seemed to be, a successful update of my Ultra 6 from 4.2.31, to 6.10.0 (Hotfix 2). After completing the update (OS 6 seemed to be running just fine) i did a manual shutdown o...
Icewaterhot
May 04, 2019NETGEAR Employee Retired
Hi Grizzi,
Can you try this link below?
https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
- GrizziMay 05, 2019Aspirant
Hi,
USB recovery for OS 6 would not work, as this is a legacy device. So based on what i am reading, if i need to do USB recovery, i need to use the 4.2 method, which i did get running, but it is not booting from the USB, which i bet it tied to the same issue with not being able to boot to the boot menu either.
