Naslok
Aug 16, 2017Aspirant
Fan in fullspeed ( readyNAS 102)
Situation: - ReadyNAS RN102 F.W. : 6.8.0 - RAIDar: 6.3.0 Problem: The fan in my Nas is continious in full speed, While the dashboard says it's not working. The temperature of the HDD's is 32 deg...
Aug 16, 2017Guru - Experienced User
It sounds like the fan sensor might have failed.
Is the NAS still covered by warranty (1 year from date of purchase)?
Marty_M
Aug 17, 2017NETGEAR Employee Retired
Hello Naslok,
Unfortunately the warranty status of the NAS is already expired. If you have a back up of the data save on the NAS you have an option to perform an OS re-install or factory reset the NAS and check if it will make any difference.
Welcome to the community!
Marty_M
NETGEAR Community Team
