Strung
Apr 21, 2019Aspirant
Fan Loud
Hello,
I have recent issue with my setup. I start my readynas RN102 and the fan is loud.
I have investigate problem and see in monitoring page one of disk with no temperature display.
Strung
Hi,
I was thinking update the firmware of hard drive. I don't think this issue ils relatée to readynas.
The fan has always been setup on silent.
Apr 22, 2019Guru - Experienced User
I doubt that updating the drive firmware will matter.
Are you seeing a rise in disk temps when the fan is loud? I realize that you aren't always seeing the temps reported.
Do you have disk spindown enabled? I believe you will see this behavior when a drive is spun down.
- StrungApr 22, 2019Aspirant
If i replug the faulty disk, the fan is loud (3200 tr/min) after few minutes and I see :
- 25 °c for first disk
- 122°C for second disk
- 50°C for CPU
I have disabled spin down but same result.
If I remove the faulty disk, the fan becomes silent after few minutes (700tr/min).
I a using this setup since 4 years without a problem... Strange
Do you think i can associated the fist disk st1000dm003 with a st100dm001 (same capacity but not in hardware compatilibty) to rebuild X-RAID ?
- StephenBApr 22, 2019Guru - Experienced User
Is disk 2 the "faulty disk"? Have you checked how hot it is when you remove it?
That will work, but generally I recommend either NAS-purposed or enterprise class drives (for instance, Seagate Ironwolf or Ironwolf Pro). WDC Red, WDC Red Pro are also good options.
Yes second disk is faulty one, it is warm but not hot !
