Strung
Apr 21, 2019Aspirant
Fan Loud
Hello,
I have recent issue with my setup. I start my readynas RN102 and the fan is loud.
I have investigate problem and see in monitoring page one of disk with no temperature display.
Apr 22, 2019Guru - Experienced User
Strung wrote:
- 122°C for second disk
If I remove the faulty disk, the fan becomes silent after few minutes (700tr/min).
Is disk 2 the "faulty disk"? Have you checked how hot it is when you remove it?
Strung wrote:
Do you think i can associated the fist disk st1000dm003 with a st100dm001 (same capacity but not in hardware compatilibty) to rebuild X-RAID ?
That will work, but generally I recommend either NAS-purposed or enterprise class drives (for instance, Seagate Ironwolf or Ironwolf Pro). WDC Red, WDC Red Pro are also good options.
