ilneill's avatar
ilneill
Apprentice
Mar 17, 2016
File permissions after RSYNC copy.
I am in the process of retiring some of my ReadyNAS Duos... yes, they have served me well, but I now have a ReadyNAS204 to replace them and stay current, blah, blah. I like new toys really, but hopef...
  • StephenB's avatar
    Mar 17, 2016
    You set user/group on the screen shown below.  I suggest guest/guest if you want fully open shares.
    It is possible that the reset itself will reset ownership to guest/guest anyway, but I'd do it first, just to be sure.
ProSupport for Business
